Sky Netgear Router
justin
Advice if you may.
I need to connect a DVR onto a Sky netgear ADSL router. I would first like to know whether this DG834 ( i think ) router will be any different than the normal netgear ones I am used to. Secondly, I not expecting any issues conneting internally but I woulkd like remote connection, will this router as normal netgears allow me to do portforwarding etc.?
I am aware the sky broadband connection won't be static IP, how often do sky connection IP's generally change?
I would really need the DVR to be networked wirelessly. Has anyone used a netgear wireless bridge for a DVR before? I have seen the netgear's wireless 'gamming' adapter model WGE111 is this the sort of thing I should be looking at.
Thanks in advance.
Advice if you may.
Thanks in advance.
The Sky branded netgear is essentially the same, but has a fixed username and password, the password being different per customer, and believe this cannot be changed. There is just then some branding in place.
You can completely re-flash the firmware with the standard netgear firmware available from the netgear site. Simply resetting the unit is not enough.
I beleive you can do all you want leaving it as a Sky branded router anyway.
Email : martin@askthetrades.co.uk
the user name is admin, password is sky usually.
I just flashed my sky router with netgear's own. Couldn't stand not having full access. It's not a bad little router
What do you mean by 'full access' what would it not let you do?
