Guest Bob Williams Posted June 28, 2004 Posted June 28, 2004 I have this alarm system in my house and I recently noticed that the siren was no longer working in the bell box. The strobe works ok but not the siren. There's voltage into the bellbox on the bell+ and the -s tags so I guess the bell box is goosed. The cmfort leds on the front of the box aren't working either, allthough there is voltage on the supply- and the supply+, so that kind off confirms that the box is goosed. So my question is ,can anyone reccomend a bell box that is compatible with the securit 700l Plus?
FASTCAR Posted June 28, 2004 Posted June 28, 2004 Texecom Odyssey , pretty good value, universal connections etc.
nikko Posted June 28, 2004 Posted June 28, 2004 Any sounder will do the job, Bob. When you get fixed up drop us a line & we'll explain the connections should you need it. I went up into the attic...I found a Stradavarius & a Picasso. Unfortunately..... Stradavarius couldn't paint, and Picasso made a shocking fiddle. My Facebook page...http://www.facebook.com/home.php#/profile.php?id=1279556853&ref=name
Guest Bob Williams Posted June 29, 2004 Posted June 29, 2004 Many thanks, When I get a Bell Box I'll be back on line if I get any problems. This is a cracking web site, I wish were more like this. Just what the web should be about! Thanks again.
