davetherave69 Posted February 3, 2009 Posted February 3, 2009 hi all just wondered if any one has used a disco smoke machine to work like a smoke clock if thay have has it worked ok or is it not a good idea to use one.
Guest RJBsec Posted February 3, 2009 Posted February 3, 2009 not a good idea to use one. Sounds like the best reply.
A-G Posted February 3, 2009 Posted February 3, 2009 hi all just wondered if any one has used a disco smoke machine to work like a smoke clock if thay have has it worked ok or is it not a good idea to use one. The smoke cloak nozzle is kept heated to make it instantly ready. The disco type takes about 5 minutes to build up to temperature. See the problem? . . . PM me for access to the SSAIB members discussion area.
davetherave69 Posted February 3, 2009 Author Posted February 3, 2009 The smoke cloak nozzle is kept heated to make it instantly ready. The disco type takes about 5 minutes to build up to temperature. See the problem? ok wont bother i just by the proper thing thanks
Tilly Posted February 3, 2009 Posted February 3, 2009 Disco versions are just too slow, and as stated, wont heat up in time for the type of volume of smoke you need...
SystemQ Posted February 3, 2009 Posted February 3, 2009 hi all just wondered if any one has used a disco smoke machine to work like a smoke clock if thay have has it worked ok or is it not a good idea to use one. The burglars could end up breaking stuff as they dance around.. System Q Ltd.
Alarm Co Posted February 3, 2009 Posted February 3, 2009 The burglars could end up breaking stuff as they dance around.. you could always stick the sensors on pulse count three the zone on double knock and put a 15 minute delay on the bell if that helps?
