DSC Power832
Guest chm0d
Guest chm0d
I was wondering if there is anyone out there that could tell me what would cause a general system trouble? There doesn't seem to be anything wrong in programming. I wish I could elloborate on this more, but I have yet to go out there to figure it out. I have it for a job tomorrow and was just hoping I could get some input on this trouble. Any replies would be greatly appreciated.
Chm0d
Does The panel have any Module's on it e.g. PC5204,PC5132 or Escort5580 module fitted?
jpaul
Yep - that would be PC5204 power supply fault - either an aux output failure or output #1 failure.
Less likely is a printer attached to PC5400 is off line.
D7
It can be caused by jamming on the wireless module, I have also seen it with Escort5580 module if its not programmed right..
Try soft reset, power the panel down then back up, you will need to set time again.
jpaul
