Galaxy 500 Bell Box Wiring, Cant Think Straight...
kensplace
I want to swap to a galaxy 500, I have had the bellbox working with a galaxy 16+ before, but not wired up the 500 yet.
Wirewise I have the following 5 wires going to the bellbox, unfortunatley some scrote nicked our ladders from the back yard so
I can't get up to the bell box to check any connections, or even remove battery from it etc....
1 - Strobe -
2 - SCB T
3 - SCB A
4 - BELL B-
5 - BELL D+
Im assuming from some old scribbled notes of the old panel that was there ages ago
Wire 1 Strobe Minus is the strobe trigger
Wire 2 SCB T is -Ve Tamper Return
Wire 3 SCB A is 0V
Wire 4 Bell B MINUS is the Bell Trigger
Wire 5 Bell D PLUS is +12V Supply for bellbox
Question is, how does this wire up to the galaxy 500?
The Bell output obviously to the no 4 wire (Bell trigger), another output for the strobe (if I use it)
+12v and 0v do they just wire up to any 12v supply in the panel?
What about the tamper return? Where on the galaxy does that connect? I notice there is a pair of tamper return connections on the board,
but there is only one wire for tamper coming from the bellbox.. Does it go into a input, or wire into that pair somehow?
My head is just not working at the moment, cant think at all!
Also, could the bell box be ran from a rio, if so again how would the tamper be connected - and is it fine to do that (may not need to, just exploring options)
cheers
Out of interest what's the max current a rio can supply. I take it that if you can run a bell (& strobe) off a rio they can deliver a fair amount, & what if it's at the end of the chain of rio's, or if 100m from panel etc?
Just getting my head around it all, not knocking etc.
1 - Strobe -
2 - SCB T
3 - SCB A
4 - BELL B-
5 - BELL D+
Wire 3 SCB A is 0V
cheers
a 16 to a 500,thats some additional protection youve added,i take it the bell cable is wired back to the 16,then just connect the 12v/0v to the power the trigger to say o/p 1001 prog'd bells then the tr to the tr (2nd term below the spkr o/p)
  kensplace said:
I want to swap to a galaxy 500, I have had the bellbox working with a galaxy 16+ before, but not wired up the 500 yet.Wirewise I have the following 5 wires going to the bellbox, unfortunatley some scrote nicked our ladders from the back yard soI can't get up to the bell box to check any connections, or even remove battery from it etc....1 - Strobe -2 - SCB T3 - SCB A4 - BELL B-5 - BELL D+Im assuming from some old scribbled notes of the old panel that was there ages agoWire 1 Strobe Minus is the strobe triggerWire 2 SCB T is -Ve Tamper ReturnWire 3 SCB A is 0VWire 4 Bell B MINUS is the Bell TriggerWire 5 Bell D PLUS
