Cctv Camera In Surveillance (monitor) Room
aleksandras1234
How is in your main practice -
If there is a large public building
(sport arena, shopping centre...) -
do you install CCTV camera in
surveillance (security) room -
to survey them (guards)?
Thank you.
As a standard, yes. For 2 reasons:
1. to protect the guards/equipment in the room, as often there is recording equipment located in or arround the room.
2. To monitor the guards if in a 24h survailance suite. To make sure that the staff are doing what they are supposed to do. Especially if the system is an ARC/CMS as quick response times are key. You can also use the video as proof (to a customer) that the guards were doing what they should be doing during monitoring times.
cheers,
D
