satsuma01 Posted February 5, 2009 Posted February 5, 2009 whats the item you would usae to take 2 cctv images down 1 coax? thanks ps new cable run isnt possible as ducts have collapsed "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
SystemQ Posted February 5, 2009 Posted February 5, 2009 whats the item you would usae to take 2 cctv images down 1 coax?thanks ps new cable run isnt possible as ducts have collapsed This is possible Collin but I'mnot sure who does the product. Its quite expensive thought are you sure you can't run in another cable? Paul. System Q Ltd.
satsuma01 Posted February 5, 2009 Author Posted February 5, 2009 This is possible Collin but I'mnot sure who does the product.Its quite expensive thought are you sure you can't run in another cable? Paul. well its possible BUT the ground would have to be dug up again to install another duct as the duct wasnt installed properly and seems to be collapsed in a few places i have already rodded it from both ends of the duct and the rod only goes so far . but yes i could re dig the ground over and install another duct to the back fence then conduit along that fence to the property. it would be a long run thoug. i suppose i could install a cat 5 cable and use all the cores to run a ptz, and 2 cameras and just ditch that old cable altogether., it must be approx 300 metres or more. "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
Alarm Protection Posted February 5, 2009 Posted February 5, 2009 Im sure the unit you need cost about !
SystemQ Posted February 5, 2009 Posted February 5, 2009 well its possible BUT the ground would have to be dug up again to install another duct as the duct wasnt installed properly and seems to be collapsed in a few placesi have already rodded it from both ends of the duct and the rod only goes so far . but yes i could re dig the ground over and install another duct to the back fence then conduit along that fence to the property. it would be a long run thoug. i suppose i could install a cat 5 cable and use all the cores to run a ptz, and 2 cameras and just ditch that old cable altogether., it must be approx 300 metres or more. Can you not pull through a strong draw wire with the existing cable then pull in two more tough direct burials through the original duct ? System Q Ltd.
james.wilson Posted February 5, 2009 Posted February 5, 2009 http://www.google.co.uk/search?q=Genie+Vid...lient=firefox-a genie do one a lot then securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
A-G Posted February 5, 2009 Posted February 5, 2009 If your duct has collapsed or been damaged, your cable could be sustaining damage and you may have to re-dig it at some time anyway. maybe worth just re-doing it now and save any future problems. Hmmm...... digging in the snow and zero temparature. Nice. . . . PM me for access to the SSAIB members discussion area.
ian.cant Posted February 5, 2009 Posted February 5, 2009 The kit your thinking of is called DUOLINK but if the ducts collapsed it probably a matter of time before the cable is unusable anyway.
dmalone Posted February 5, 2009 Posted February 5, 2009 well its possible BUT the ground would have to be dug up again to install another duct as the duct wasnt installed properly and seems to be collapsed in a few placesi have already rodded it from both ends of the duct and the rod only goes so far . but yes i could re dig the ground over and install another duct to the back fence then conduit along that fence to the property. it would be a long run thoug. i suppose i could install a cat 5 cable and use all the cores to run a ptz, and 2 cameras and just ditch that old cable altogether., it must be approx 300 metres or more. there is definitely a device which does this you can purchase them from norbains i think they are about two hundred quid though
james.wilson Posted February 5, 2009 Posted February 5, 2009 the duolink is the same as the genie product (well same case lol) but yes as ian says thats the known brand securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
