DSC PC 1565 Classic
housty
Hi all
Does anyone know if there is a NVM chip you can remove when the panel has enginneers code is locked in for a DSC PC 1565 Classic i looked in the manual and its not too informative???
housty
Houston Security Systems Ltd
Intruder alarms
CCTV
Door entry
Fire protection
Networking
SSAIB Approved
Don't think the NVM is removeable on that one. Why don't you just hardwire default the panel? - Careful though - If I remember correctly British Gas (I think...) had their own version of this panel - and if you default it, it defaults to their own engineer's code, not the DSC one.
You can't remove the NVM chip, and a hardwire default will not work if the eng code is locked (option [990] Installer Lockout Enable)
Is it a BG panel?
jpaul
jpaul,
Can you use the upload/download software to download as is and then change th eng code, this works on gardtec equipment but never tried on DSC ???
Clive
Yes, but you need the eng code and Downloading Access Code to log onto the panel. :(
jpaul
Hi
its not been put in by BG and i can bet it has been locked.
housty
Intruder alarms
CCTV
Door entry
Fire protection
Networking
SSAIB Approved
What makes you think the engineer's code is locked? Is it because you are fearing the worst or do you have another reason?
I assume you are taking the system over for a customer? If so, is the installing company still around?
If the worst comes to the worst, you could send the panel to Elvey for defaulting:
http://www.elveysecurity.co.uk/
  • 3 years later...
Great! (NOT!)
I've been asked to service a system for a profoundly deaf customer...they have a DSC PC1565 panel...installed by BG!
The back-up battery is obviously duff (the system is now 10 years old!!), and it won't now respond to their user code.
Me thinks the panel will now be locked...or will it?
Ultimately, I suppose I need the engineers manual, but after the earlier posts it appears the BG system wont default to DSC's standard engineers code. Is that right?
Thanks for any help anyone can give.
Great! (NOT!)
The code is not locked, but if you default it it will go back to their default codes..
BG will default the panel back to DSC standards for a small fee :ninja:
So, I'm probably best not defaulting it?
I certainly don't need to change any settings - although it's probably the most simple system you could imagine - just three pir's and that's it!
Apparently the system is 10 years old (no wonder the battery is duff!) and hasn't been subject to any maintenance during this time :(
I don't yet understand why the user code didn't appear to be responding, but I understand the woman had taken a look in the end station herself so would have tripped the tamper of course... :unsure:
Anyway. I hope to be getting to check it all out either tomorrow or Thursday. I have a few copies of the user manual, but even in my huge file of engineers manuals, this is one of the missing ones - and I have some really obscure ones! :huh:
