Minerva Mx1000 Fire Panel
Leigh1983
You cant change the mode of operation , from heat and smoke to say just a heat, has to be done on laptop.No difference in terms of changing address and device between mx1000 and mx 4000.
How can i delete an sensor address. I dont want to appear that the sensor is unconfigurated (u).
This an only be done via the config programming (ie - software and lappy).
so i understand that i cant deleted from the operator panel?
my problem is that, i need to change an 801P detector with an new 801PH detector, and when i want to change the address 255 (pre-programmed 801PH) with the address that 801P had it, FROM THE OPERATOR PANEL MINERVA MX4000 FIRE PANEL. i have the engineering code.
I have an service manual but is from an old version (firmware v1.0 year 2000) my firmware is v8.1 (2005 )
Thanks,
