virdi Posted February 10, 2009 Posted February 10, 2009 Hi all, I want to fit to Proximity Remote Keypads to my system - As I want to make it easy for my parents to arm and disarm etc... But what would happen if you lose the Proximity Tag? Can a tag be cancelled from the system via programming etc..? The system I'm using is a Scantronic 9651 Thanks
Guest RJBsec Posted February 10, 2009 Posted February 10, 2009 But what would happen if you lose the Proximity Tag? Can a tag be cancelled from the system via programming etc..? Yes it can
virdi Posted February 10, 2009 Author Posted February 10, 2009 So each tag has it's own ID kinda thing?
Guest RJBsec Posted February 10, 2009 Posted February 10, 2009 So each tag has it's own ID kinda thing? Correct.
kka Posted February 11, 2009 Posted February 11, 2009 As RJB says, each tag is programmed to the panel seperately. so if you lose one, all that is needed is to program that tag's number out. buy a new tag and program the new one to the systems. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
