Wired System With Wired Sounder?
mgbgt2
Im looking for a hybrid system (wireless and wired sensors) for DIY install that can be used with a hard wired external sounder.
(I don't want to have to go up long ladders every year or so to replace the battery in the sounder box)
Most of the wireless systems such as the Risco Wisdom and the Scantronic Homelink 75 can only be used with their own wireless sounders - I have checked with the technical support lines of these companies and they say that it may be possible to attach a conventional wired sounder but only with additional relay modules.
Are there any good quality hybrid systems available where I can directly connect a conventional wired sounder without the complexity if additional relays?
I've got a detached garage (that needs to connected to the main house alarm) and I want to be able set /un-set the alarm with a wireless key fob as the garage is often the last/first exit/entry point.
I've considered a Risco 490x with add-on wireless module, but cannot determine if the wireless key-fobs will work with this configuration.
Final consideration is good battery backup as living in the country it is not uncommon to get 12 hour+ power outages during storms, so that probably rules out Visonic Powermax as that only has small NiMh re-chargables.
All the required features were available in my old A1 alarm, but that has become unreliable after about 7 years and the company has dissapeared.
Any advice would be appreciated.
Galaxy G2-20 will do all that you need but it's not really a panel for DIY.
Try Scantronic Homelink 55. Better than 75 - by a mile or two, and will work with every wired sounder I'm aware of.
I'd guess with 7Ah batt you'll get 24+ hrs standby (over 2days on some jobs we got).
Guest old-hand
As above the G2-20 will do it.
Or up the battery on a Visonic Powermax.
cheers
The 490x will do this and does take a 7AH battery but if you want bigger battery life i would go for a 595 metal panel.
The new Scanny I-on16 is very good aswell but only takes a 7AH.
Scanny I-on16, not hybrid. :)
Would the Scantronic 500r meet my needs? looks like a simpler panel more suitable for DIY
Is this an old model?
I beleive the wireless is the older 433 Mhz - is this a real problem for a DIY install that can't be certified?
Old model & old frequency.
868.6625Mhz is a dedicated freq band for intruder. There will be other types of eqpt on the 433 once its been allocated.
