sirocco Posted February 15, 2009 Posted February 15, 2009 Does anyone know which model keyfob will work on a Galaxy 2-20 system with an RF portal installed. The manual refers to ADEMCO/HONEYWELL 5804 but the istallation manual for that keyfob says it's for a system with 5800 receiving capabilities. My understanding is that that the RF Portal does not recognise 5800. Confused !
Guest RJBsec Posted February 15, 2009 Posted February 15, 2009 TC805HF or TCB800M will work with G2-20 RF Portal the TCB800M can be programmed for early or current version of Portal.
sirocco Posted February 15, 2009 Author Posted February 15, 2009 TC805HF or TCB800M will work with G2-20 RF Portal the TCB800M can be programmed for early or current version of Portal. Thanks! Another costly mistake avoided!
