Powermax + With Wired Sounder
mgbgt2
I'm considering getting a Visonic PowerMax + but want to use a conventional wired sounder (Siren, Strobe, 12v supply to battery backup, anti-tamper) but the standard configuration uses a fully wireless sounder.
I've read the PowerMax + installation guide, but I'm still not sure how I would connect a wired sounder.
If the sounder connections are:
Hold +
Hold -
Trg -
Stb -
Return
How would I connect this to the PowerMax + and would it need any special programming?
Does the PowerMax + have enough power to drive a typical wired sounder?
Guest old-hand
Watch the power consumption of the sounder Powermax+ is a bit limited.
Its fairly easy to hardwire into the panel. No special programming needed.
Not got a manual to hand and cannot remember the connections ( hic had a beer )
cheers
Hello, The info is on page 6 of the install manual.
Hold + goes to 12v
Hold
