the-oneil Posted February 18, 2009 Share Posted February 18, 2009 Could someone kindly correct me if I am wrong I was told that the police would not respond unless The Alarm is monitored -of course There is a confirmed incident triggered by two activations (ie 2 sensors) The system must have two local key holders Which I can live with I suppose. However, I was also told - by a reputable installer (NSI Gold)....etc. that, the police will not respond unless * The system must have a proximity keypad - Seriously!! * The second sensor is triggered within 30 minutes from the 1st one, otherwise it is considered a new incident. * The System must have a maintenance contract with 2 annual maintenances - NOT one. My questions really are 1- Are these last three points actually true? Or does it depend on which police force? 2- Is the Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27025-speech-dialer-vs-monitored-alarms/ Share on other sites More sharing options...
A-G Posted February 18, 2009 Share Posted February 18, 2009 However, I was also told - by a reputable installer (NSI Gold)....etc. that, the police will not respond unless* The system must have a proximity keypad - Seriously!! Depends on a few variables. .... but probably correct. * The second sensor is triggered within 30 minutes from the 1st one, otherwise it is considered a new incident. * The System must have a maintenance contract with 2 annual maintenances - NOT one. True & True My questions really are 2- Is the . . . PM me for access to the SSAIB members discussion area. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27025-speech-dialer-vs-monitored-alarms/#findComment-225224 Share on other sites More sharing options...
Guest old-hand Posted February 18, 2009 Share Posted February 18, 2009 Could someone kindly correct me if I am wrongI was told that the police would not respond unless The Alarm is monitored -of course There is a confirmed incident triggered by two activations (ie 2 sensors) The system must have two local key holders Which I can live with I suppose. However, I was also told - by a reputable installer (NSI Gold)....etc. that, the police will not respond unless * The system must have a proximity keypad - Seriously!! * The second sensor is triggered within 30 minutes from the 1st one, otherwise it is considered a new incident. * The System must have a maintenance contract with 2 annual maintenances - NOT one. My questions really are 1- Are these last three points actually true? Or does it depend on which police force? 2- Is the Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27025-speech-dialer-vs-monitored-alarms/#findComment-225226 Share on other sites More sharing options...
Guest RJBsec Posted February 18, 2009 Share Posted February 18, 2009 * The System must have a maintenance contract with 2 annual maintenances - NOT one. Grade 2 system can have 1 maintenance visit and one remote via the installer's remote diagnostic software. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27025-speech-dialer-vs-monitored-alarms/#findComment-225233 Share on other sites More sharing options...
james.wilson Posted February 18, 2009 Share Posted February 18, 2009 yes thise points are correct. As oxo points out you do have options on the proximity keypad that will need to be explained to you you have 6 choices but 3 are the only one to consider. 1. as you have already discovered disarm using a prox device 2. entry door disables confirm, if you use this then you dont need prox as once you open your front door all confirmation is disabled (ie the police bit) but while you can open the door with a key, someone else can open the door with a boot.... and disable all confirmation. Strongly not advised IMO 3. as oxo says use a shuntlock or access system on the front door, that way if the door is booted in confirm is not disabled as the lock will still be locked. but prox is usually the most cost effective, a shunt lock is the best IMO (in most instances) securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27025-speech-dialer-vs-monitored-alarms/#findComment-225234 Share on other sites More sharing options...
chexsec Posted February 22, 2009 Share Posted February 22, 2009 3, Not exactly as the monitored one will signal more items like power failures battery faults ect. In reality a speech dialler can signal these faults too Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27025-speech-dialer-vs-monitored-alarms/#findComment-225809 Share on other sites More sharing options...
james.wilson Posted February 22, 2009 Share Posted February 22, 2009 yes but not all of them as your limited by outputs/inputs. a speech dialler cant touch an extended digi. no test calls for one. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27025-speech-dialer-vs-monitored-alarms/#findComment-225817 Share on other sites More sharing options...
