leeroy Posted February 19, 2009 Share Posted February 19, 2009 hi is it possible through a pc not at my home, to somehow turn on my out door security light when needed? and if so can i have some details and links to the devices needed? thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/ Share on other sites More sharing options...
Guest old-hand Posted February 19, 2009 Share Posted February 19, 2009 You can do it with a mobile phone from anywhere in the world if you like. It is called a GD06 GSM dialer. it can report things to your phone and be remotely controlled with two inputs if memory serves me right cost is about Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/#findComment-225360 Share on other sites More sharing options...
leeroy Posted February 19, 2009 Author Share Posted February 19, 2009 thanks, have found one. if possible id still like to be able to do this through my laptop, thanks for the swift response though, its something to think about if i cant do it through a laptop and internet connection. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/#findComment-225362 Share on other sites More sharing options...
Guest old-hand Posted February 19, 2009 Share Posted February 19, 2009 thanks, have found one.if possible id still like to be able to do this through my laptop, thanks for the swift response though, its something to think about if i cant do it through a laptop and internet connection. Set up SMS on your laptop as well. Plenty of programmes about just google Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/#findComment-225363 Share on other sites More sharing options...
justin Posted February 19, 2009 Share Posted February 19, 2009 I would use a CCTV DVR with controlled outputs and with the bonus of adding cameras later. Just curious though when would you turn the lights on and why? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/#findComment-225375 Share on other sites More sharing options...
Guest old-hand Posted February 19, 2009 Share Posted February 19, 2009 I would use a CCTV DVR with controlled outputs and with the bonus of adding cameras later. Just curious though when would you turn the lights on and why? Thats one of the next steps to take. However the question was how to remotely turn on a light. I took the easiest and possibly cheapest option. Given the lack of other information. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/#findComment-225377 Share on other sites More sharing options...
leeroy Posted February 19, 2009 Author Share Posted February 19, 2009 I would use a CCTV DVR with controlled outputs and with the bonus of adding cameras later. Just curious though when would you turn the lights on and why? light is pir, activated wen approcached. however there are times when i manualy activate the light, forinstance poeple standing at top of my yard on the street, this does not activate the light as they out of reach of pir. if im monitoring my cctv from remote location, and see "intruders" at top of the yard, i wanted to be able to acctivate the 500w light, which allows me to use one of my ptz cams to see more clearly. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/#findComment-225392 Share on other sites More sharing options...
justin Posted February 20, 2009 Share Posted February 20, 2009 light is pir, activated wen approcached.if im monitoring my cctv from remote location, and see "intruders" at top of the yard, i wanted to be able to acctivate the 500w light, which allows me to use one of my ptz cams to see more clearly. This is exactly what a DVR's we fit would allow you to do. As your controlling for instance your dome remotely on camera, say input 3. Activate alarm command 3 and this would in turn switch your light on. We normally use this function firstly to open electric gates and barriers. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/#findComment-225479 Share on other sites More sharing options...
SystemQ Posted February 20, 2009 Share Posted February 20, 2009 This is exactly what a DVR's we fit would allow you to do. As your controlling for instance your dome remotely on camera, say input 3. Activate alarm command 3 and this would in turn switch your light on. We normally use this function firstly to open electric gates and barriers. If you have not already got a DVR then buying one with this feature is a good option to acheiving your aim. Paul. System Q Ltd. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/#findComment-225483 Share on other sites More sharing options...
digitalwitness Posted February 20, 2009 Share Posted February 20, 2009 You mentioned in another post that you have a Pansonic DVR which you purchased off ebay, does that not have remote activated relays? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27038-remote-turning-on-of-flood-light/#findComment-225487 Share on other sites More sharing options...
