nevergiveup Posted February 21, 2009 Posted February 21, 2009 Hi all, I am a home installer and have installed a wisdom wireless panel with a XS3D sounder but I keep getting a bell box tamper fault alarm. I know this is basic stuff but can anyone confirm the wiring configuration please between panel & sounder I currently have: Panel ------------------- bell box Com----------------------OV Bell Tmpr----------------- Tmpr Bell - -----------------------S - Bell + -----------------------12v Bell - -------------------------St Any help would be appreciated. Chris
Guest RJBsec Posted February 21, 2009 Posted February 21, 2009 I'm sure someone will help soon but multiple posts will just irritate!
nevergiveup Posted February 21, 2009 Author Posted February 21, 2009 I'm sure someone will help soon but multiple posts will just irritate! Ok, sorry.. Chris
topgunn Posted February 21, 2009 Posted February 21, 2009 Hi all,I am a home installer and have installed a wisdom wireless panel with a XS3D sounder but I keep getting a bell box tamper fault alarm. I know this is basic stuff but can anyone confirm the wiring configuration please between panel & sounder I currently have: Panel ------------------- bell box Com----------------------OV Bell Tmpr----------------- Tmpr Bell - -----------------------S - Bell + -----------------------12v Bell - -------------------------St Any help would be appreciated. Chris Hope to have fitted a 2k2 resistor between the bell tmp and common
nevergiveup Posted February 21, 2009 Author Posted February 21, 2009 Hope to have fitted a 2k2 resistor between the bell tmp and common Thanks & yes, already fitted 2k2 resistor bwtween bell tmp & com but still activates alarm showing bell box tmpr fault? Supporting docs suggest further 2k2 between bell + & Bell - but this does not seem to make much difference. Thanks
topgunn Posted February 21, 2009 Posted February 21, 2009 Thanks & yes, already fitted 2k2 resistor bwtween bell tmp & com but still activates alarm showing bell box tmpr fault?Supporting docs suggest further 2k2 between bell + & Bell - but this does not seem to make much difference. Thanks Make sure the back tamper is contacting the wall. pop a screw behind it. possibility With the prosys panel they tell u to put a 2k2 but it needs to be twisted with a 4k7 to satisfy the panel.
nevergiveup Posted February 21, 2009 Author Posted February 21, 2009 Make sure the back tamper is contacting the wall. pop a screw behind it. possibilityWith the prosys panel they tell u to put a 2k2 but it needs to be twisted with a 4k7 to satisfy the panel. Ok, will do. Do my other panel to bell connections look ok? Chris
topgunn Posted February 21, 2009 Posted February 21, 2009 Ok, will do. Do my other panel to bell connections look ok? Chris You have two bell - or have u just connected the bell and strobe to the same terminal on the panel?
nevergiveup Posted February 21, 2009 Author Posted February 21, 2009 You have two bell - or have u just connected the bell and strobe to the same terminal on the panel? No, 1 bell with both connected to Bell -
topgunn Posted February 21, 2009 Posted February 21, 2009 No, 1 bell with both connected to Bell - yh thats ok. check parameter 32
