Risco Wisdom Panel To Xs3d Sounder
nevergiveup
Have you checked the tamper spring that when you close the bell you hear the spring/tamper click close??
If not then bend the metal untill you hear it close...
cheers
cheers
Good point, I'll check that tomorrow & thanks for all your other advice.
Regards
Chris
i use the xs3d and the tamper leaf will need bending.
check programming to
