Scantronic 9600 installation
Guest tandyuk
Guest tandyuk
Hi,
I have just installed a 9600, configured etc.
The system seems o be ignoring entry times, or ive configured something wrong.
Group A has 3 pirs, 1 & 2 are set as normal night, pir 3 in our halway is set as entry route.
On setting the alarm, leaving the zone and ruturning a few mins later,
instead of the 30 sec delay i entered to allow deactiviation, the alarm sounds instantly.
The Instant Bells option is disabled, and Delayed entry alarm is enabled.
Thanks in advance,
TandyUK
Guest Guest
Sounds as though you have programmed the entry zone wrong. Check this!
Guest tandyuk
Can you give me any suggestions as to how this zone should be setup?
Im not an alarm installer, and the installation manual doesnt actually say what the different options mean, so i could quite easily have missed an important one.
All the other zones work as we want them to.
Guest Guest
The door you enter the building through shoulf be set as "final door"
If you have to pass a detector to get to the keypad then this should be programmed as "entry route"
If you have a part set, then the same principal applies.
Guest tandyuk
Makes a lot more sense now :)
..heads off to reprogram the zone....
Thanks
Guest tandyuk
now works blissfully,
Thanks for you help :)
