soulstyle Posted February 23, 2009 Posted February 23, 2009 Hi, I have just bought a G2 to use in my house. I have it set-up tempory in my workshop at work to figure out how it works etc. Have managed to clear all faults apart from one, bell tamper. I dont have anything connected to the panel at present, how do i clear the bell tamper.
woodpecker Posted February 23, 2009 Posted February 23, 2009 Hi,I have just bought a G2 to use in my house. I have it set-up tempory in my workshop at work to figure out how it works etc. Have managed to clear all faults apart from one, bell tamper. I dont have anything connected to the panel at present, how do i clear the bell tamper. Try a 1k resistor from Aux Tamp to GND
soulstyle Posted February 23, 2009 Author Posted February 23, 2009 Try a 1k resistor from Aux Tamp to GND Thought it might be, but didnt want to try without asking. Couldnt see anything in the manual. Many thanks
goncall Posted February 23, 2009 Posted February 23, 2009 just put a wire link between 0v and t first 4 terms(sorry 5 terms) on lhs on pcb are bell connections
soulstyle Posted February 26, 2009 Author Posted February 26, 2009 Thanks all. Second question, got everything sorted but the internal sounder. Sound from the internal sounder is really low. I have connected it to the bell 0V and trig output 1002. The sounder has a 160ohm resistor in series with positive, is this needed?
goncall Posted February 26, 2009 Posted February 26, 2009 Thanks all.Second question, got everything sorted but the internal sounder. Sound from the internal sounder is really low. I have connected it to the bell 0V and trig output 1002. The sounder has a 160ohm resistor in series with positive, is this needed? it needs to go in aux +v and 1002,you can also adjust the volume in the programing
Guest old-hand Posted February 26, 2009 Posted February 26, 2009 Thanks all.Second question, got everything sorted but the internal sounder. Sound from the internal sounder is really low. I have connected it to the bell 0V and trig output 1002. The sounder has a 160ohm resistor in series with positive, is this needed? I`d drop the resistor if I was you.
