bogflogger Posted February 24, 2009 Posted February 24, 2009 Hi everyone, Before I start I am not (as you'll probably gather) an alarm engineer. I've just taken over a property that has a scantronic 9800 key pad and I think it has a scantronic box with a versus redcare system. The previous owner had a contract with ADT that is now defunct. The redcare is not operational. I have the old users access codes to enable and disable the alarm plus I was given an engineers code that I was told would work if I had problems. Well I have problems!! The service and fault lights are constantly illuminated and I am getting EF, rr, t4 error codes. I cannot clear the panel and reset the system. I've tried the engineers code and it does not work. I don't really want to get ADT out as I've had dealings with them before and not been that impressed (the engineers were excellent though!!) After some research on the internet I've tried resetting the system and removing the NVM chip but with no success. If anyone can help it would be much appreciated.
Guest RJBsec Posted February 24, 2009 Posted February 24, 2009 Do you want a monitored system for police response or just an audible-only?
bogflogger Posted February 24, 2009 Author Posted February 24, 2009 Do you want a monitored system for police response or just an audible-only? Hi, thanks for your post. Initially, audible only. I really want to get the system up and running and then look at upgrading later.
Guest RJBsec Posted February 24, 2009 Posted February 24, 2009 A local installation company should be able to default the system for you and re-programme it as necessary. It probably will be in need of a service and battery replacement so it would be money well spent to combine this in a single engineer visit.
bogflogger Posted February 24, 2009 Author Posted February 24, 2009 A local installation company should be able to default the system for you and re-programme it as necessary. It probably will be in need of a service and battery replacement so it would be money well spent to combine this in a single engineer visit. I was hoping to get it up and running tonight, tall order I know, I've had some suspicious 'customers' in the showroom today.
hpotter Posted February 24, 2009 Posted February 24, 2009 I don't really want to get ADT out as I've had dealings with them before and not been that impressed (the engineers were excellent though!!) Sounds like you need an excellent engineer! ASAP. Give them a call - the devil you know! (or call local firm as posted).
bogflogger Posted February 24, 2009 Author Posted February 24, 2009 Sounds like you need an excellent engineer! ASAP.Give them a call - the devil you know! (or call local firm as posted). Thanks for your advice, engineer on his way. Many thanks.
