Galaxy G3 Ring Mobile Or Sms?
woodpecker
Guest old-hand
Yes, it can send SMS messages.
You`ll need a centre number programmed into the panel by an engineer.
If you are already connected to a monitor station just list the mobile No as a key holder to be notified ! .
www.AllanMoncrieffAlarms.com
The system isn't monitored at the moment, it will be, but at the moment I am the engineer, so can I program it or will this not work until it is monitored, I don't have a centre number?
Guest old-hand
For normal use the following settings should be used.
option 56.1.17.1 = The recipient mobile number
option 56.1.17.2 = 07958879889 ( Centre number T-Mobile)
That should help
That should help
Perfect! That works really well, is it possible to add a second mobile number so it texts 2 mobiles?
Thanks.
