leeroy Posted March 14, 2009 Posted March 14, 2009 im gona have a look at your router soon, have a look in the dvr settings look for the http port and jot down port it is (probably will be 80), have you got any other network devices that use your router via lan or wifi? just asking as we may need to asign a internal static ip addy to the dvr, infact we are going to assign a static ip addy for the dvr. just gona loook through the router manual to see if the settings are similar to my netgear. also if your routers using the default password for admin change that aswell can you give me a link to a manual of your router, just looked on netgears site and cant find it, should be able to set it up even if you cant find a online manual. when you log into the router, have you got the settings down the left hand side, can you see dynamin dns setting near the bottom on the lefft.
Mattyg2004 Posted March 14, 2009 Author Posted March 14, 2009 im gona have a look at your router soon, have a look in the dvr settings look for the http port and jot down port it is (probably will be 80), have you got any other network devices that use your router via lan or wifi? just asking as we may need to asign a internal static ip addy to the dvr, infact we are going to assign a static ip addy for the dvr.just gona loook through the router manual to see if the settings are similar to my netgear. also if your routers using the default password for admin change that aswell Its (the router)using a different Password Http port IS 80 I have a ps3 hard wired to router my main pc hard wired and the mrs laptop is wireless through router
Mattyg2004 Posted March 15, 2009 Author Posted March 15, 2009 im gona have a look at your router soon, have a look in the dvr settings look for the http port and jot down port it is (probably will be 80), have you got any other network devices that use your router via lan or wifi? just asking as we may need to asign a internal static ip addy to the dvr, infact we are going to assign a static ip addy for the dvr.just gona loook through the router manual to see if the settings are similar to my netgear. also if your routers using the default password for admin change that aswell can you give me a link to a manual of your router, just looked on netgears site and cant find it, should be able to set it up even if you cant find a online manual. when you log into the router, have you got the settings down the left hand side, can you see dynamin dns setting near the bottom on the lefft. yes and try this link http://documentation.netgear.com/wnr834b/e.../FullManual.pdf Again thanks for the help
Mattyg2004 Posted March 16, 2009 Author Posted March 16, 2009 Update: Ok still not got it working over the internet yet. Happy with the nighttime pictures (going to get a IR illuminator soon) Daytime pictures are very good. Still trying to get my head around all the setting on the HD500 like how do i set it to constantly record and then overwrite old footage. At the moment it has two 137 GB drives can I upgrade these to much bigger drives (are they normal IDE drives??) for all your help guys.
davetherave69 Posted March 16, 2009 Posted March 16, 2009 Update:Ok still not got it working over the internet yet. Happy with the nighttime pictures (going to get a IR illuminator soon) Daytime pictures are very good. Still trying to get my head around all the setting on the HD500 like how do i set it to constantly record and then overwrite old footage. At the moment it has two 137 GB drives can I upgrade these to much bigger drives (are they normal IDE drives??) for all your help guys. What cams did you buy in the end they look good pitcures
Mattyg2004 Posted March 16, 2009 Author Posted March 16, 2009 These ones. http://www.eneo-security.com/system/web/en...plate=a15_92103 I'll put up some pics of daytime tomorrow. I'm happy just need to set it up properly
davetherave69 Posted March 16, 2009 Posted March 16, 2009 These ones.http://www.eneo-security.com/system/web/en...plate=a15_92103 I'll put up some pics of daytime tomorrow. I'm happy just need to set it up properly the wife wont have them on the house as they are 2 big will need 2 get dome type 2 meney to chose from is the lighting good were you are 2 get pitures that good
Mattyg2004 Posted March 16, 2009 Author Posted March 16, 2009 Not really there is a street light 4 doors down apart from that you can trip over things on the floor as you cant see where your going. Really happy with the cameras Paid
Doktor Jon Posted March 17, 2009 Posted March 17, 2009 Mattyg2004, It's difficult to tell from the night shot, but with the "Home Alley" camera, at the moment the lens coverage looks a bit too wide IMHO. If you have a varifocal lens fitted, it may be worth dropping the camera perhaps 8 - 12 degrees, and then zooming in a bit to get less wall and better images of any peeps coming up the side ...
Mattyg2004 Posted March 18, 2009 Author Posted March 18, 2009 Mattyg2004,It's difficult to tell from the night shot, but with the "Home Alley" camera, at the moment the lens coverage looks a bit too wide IMHO. If you have a varifocal lens fitted, it may be worth dropping the camera perhaps 8 - 12 degrees, and then zooming in a bit to get less wall and better images of any peeps coming up the side ... Thanks john, Hav'nt really had time to play yet. I will change the focus on the alley ASAP I have uploaded some daytime pics.(excuse the mess in the middle of doing the place up) I know it kinda gives any burglars reading the forum a chance to see what i can see. but more cameras are to be fitted soon and the front one poss replaced by a PTZ dome. With regards to the DVR i'm not sure if i have set it up correctly. I have it set on best quality.(SF) it has two 127 GB drives so should be able to record for quite some time with only 2 cameras. However when I try to set it to record for any more than 24hrs it reduces the frame rate. Any ideas on how to set it up to record 24/7. I dont want to go away for a few days come back find out been burgled go to dvr and find that it did record it but has now recorded over it again. Sorry pro guys I bet you hate noobies who try and save some cash then get you lot to help them for free
