Control Panels With Sms Notification
Terry
your euro does cost per message and also has to dial the CHC every 2 weeks (might be monthly) which is a premium rate call.
If i were you id check you bills again and you will notice calls to an 07 number. THis is chnarged at your normal rate to mobiles.
However if you have free calls to mobiles in your package it may well be free, but that would be the same for any panel using land line sms wouldnt it.
can be disabled if not i would not of done it only need to set it up once on that number so like 50p and then in sms options disable test calls 4 mounths and no odd calls :) lol yea my
it uses std outputs (well links in fact) and is dimension only.
Didnt know you could disable chc i thought that made it report chc failures. Been a while since i used euros regually so it may have changed.
my unit is on old v3 euro meridian 44 no chc faults yet dono if thay have put it in newer units i dont think much has changed though just some pd6662 stuff and masking + fault eol, mainboard layout same as pironixs now, but both made in same factory i think i will stick to castle units though, diffrent farmware so pironixs menu on those ones :banned: in less it has got better to use lol, new ice blue rkp, also thanks dident know that about touch center not seen one yet and doing shops only probly wont see one :( allthough would like to see touch center & euro touch unit but @
  • 2 years later...
Hi sorry to jumpin on this topic. Can you tell me how I can get a control centre number? Do i need to setup a contract with one or is it simply a per text charge?
Check out http://riscogroup.co.uk PRODUCTS, CPX OR 601 PANELS. These will do all except GSM.
The panels have a VOCOM communicator built into them.
AbleAlarmMan
Able Alarm Ltd
gsm unit can be fitted that can text message, but vocom has voice message that will inform the recipiant of the user setting and unsetting the system.
AbleAlarmMan
Able Alarm Ltd
vocom and modem built in.
AbleAlarmMan
Able Alarm Ltd
