sirocco Posted February 27, 2009 Posted February 27, 2009 Can someone help clear my addled brain! Having installed a Galaxy G2-20 in a domestic premises I have checked out all the hardware comms etc and am now programming zones. The final exit door has a regular door contact and I want this to terminate the setting procedure on leaving the premises. I would like to initiate a 30 sec delay whilst setting and for this to be terminated as soon as the door is finally closed and look forward to hearing the system set confirmation tones. The door is set as Zone 1001 on the main panel and I have programmed this Zone as exit (menu 52 1 01) I have set the exit time parameter to 0 secs (Menu 51 04) and hey presto the setting procedure will not terminate on closing this final door. If I set the exit time parameter back to 30secs it will set after 30 secs but the setting procedure is not cut short by the closure of the door. Am I missing something really basic?
james.wilson Posted February 27, 2009 Posted February 27, 2009 yep what does parameter 08 say its setup as? 08=Exit Terminate id suggest it is set to no. You will need to chnage to 1=full set only securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
goncall Posted February 27, 2009 Posted February 27, 2009 Can someone help clear my addled brain!Having installed a Galaxy G2-20 in a domestic premises I have checked out all the hardware comms etc and am now programming zones. The final exit door has a regular door contact and I want this to terminate the setting procedure on leaving the premises. I would like to initiate a 30 sec delay whilst setting and for this to be terminated as soon as the door is finally closed and look forward to hearing the system set confirmation tones. The door is set as Zone 1001 on the main panel and I have programmed this Zone as exit (menu 52 1 01) I have set the exit time parameter to 0 secs (Menu 51 04) and hey presto the setting procedure will not terminate on closing this final door. If I set the exit time parameter back to 30secs it will set after 30 secs but the setting procedure is not cut short by the closure of the door. Am I missing something really basic? prog it final..
Johnny Posted February 27, 2009 Posted February 27, 2009 The door needs to be programmed Final i think its 52-01. If i remember correctly Exit is a walk through but if im wrong someone will claify..........
james.wilson Posted February 27, 2009 Posted February 27, 2009 final on a 2-20 does not mean final as in a g3, dimension or classic on a g2 you also need to tell it if its to terminate or not. It defaults to not securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
goncall Posted February 27, 2009 Posted February 27, 2009 final on a 2-20 does not mean final as in a g3, dimension or classicon a g2 you also need to tell it if its to terminate or not. It defaults to not exit means the same on all tho..if et is default he doesnt need to change anything except prog zone final..
sirocco Posted February 27, 2009 Author Posted February 27, 2009 yepwhat does parameter 08 say its setup as? 08=Exit Terminate id suggest it is set to no. You will need to chnage to 1=full set only thanks Redbull, is that in addition to the exit time parameter 51.04 being set to 0 ? I'll give it another go in the morning when the siren wont disturb the neighbours!
Guest RJBsec Posted February 27, 2009 Posted February 27, 2009 Programme zone as Final. Set exit time 51.04 to 00.
james.wilson Posted February 27, 2009 Posted February 27, 2009 and set 51.08 to something other than off securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Guest RJBsec Posted February 27, 2009 Posted February 27, 2009 and set 51.08 to something other than off Indeed ... but I thought you already said that
