Site signal transmission
Guest chris.tatt
Guest chris.tatt
Hi all.
Just a pointer in the right direction.
I mainly install the Menvier range, but have hit a wall with this project.
I look after a large site at which there is a mixture of panels, approx 70 in all.
There is currently a system in place which tranmits all the alarm signals via a home made plc over a 2 wire rs485 network. This plc has causes me a few problems recently and the client wishes to remove it and fit a current standard system.
I hoped I could have managed with the menvier range but the networks, even on the the ts2500 panels cannot manage the length of cable run.
One part of the network is approx 1000Mtrs and another is 2500Mtrs using a few rs485 repeaters.
Also the client wants a good pc recieving graphics package for the site.
I have briefly looked at using the galaxy system and found a few notes about its rs485 capabilities but my knowledge of these panels are limited.
Advice of which system would suit best is what I need.
Thanks in advance.
If more info is needed please ask.
Chris
Mids.
  • 1 month later...
try using the europlex 3gs and get in touch with a company called cortech technologys for the graphics and integration of all panels its not cheap though
install galaxies, fit ethernet modules, use customers' lan to transmit alarm signals to galaxy alarm monitoring on a pc. no call costs and no impact on lan either, quickest transmission method if lots of things are going on at once!
or, if they have their own site-wide phone system fit telecoms modules and set up to alarm monitor. call cost = zero
There are various front end graphical interfaces with touch screen etc.
or if that is too expensive, aritech do transport pc client software.
Personally I do not like aritech but the transport pc package is quite good.
TSS
Communication is "A question asked, and an Opinion given." I offer mine to help you with yours.
Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
I'm with alarmbloke on this,
Galaxy and ethernet module seems the best solution, i'd never thought about the PABX solution though, nice one alarm bloke.
You learn something new every day :rolleyes:
Regards
Bellman
Regards
Bellman
20031[/snapback]
Got a local p*****force using it.... they'll never lose their police reponse tho... :D
TSS
Lantronix do universal TCIP interfaces and then you can monitor over an existing data network then you can use a propritory monitoring software to decode the alarm signals and display the information as you want ( I will dig out the name in the office tomorrow)
But the easier solution is the galaxy setup, as they have a working IP setup and monitoring solution of the shelf.
What problems are you having.
Colin.
Hi all.
Thanks in advance.
Chris
Mids.
16780[/snapback]
Chris, We (Menvier) now produce a TCP/IP interface that will work with any panel. If you tell me where you are based, Ill put you in touch with your local guy, Mick
Mick Gates
Regional Sales Manager- Intrusion Products
Bosch Security
www.boschsecurity.co.uk
  • 1 month later...
20027[/snapback]
:o How about power backup??? I can guess that LAN is not very powerloss proof...
25650[/snapback]
I think you will find that most large sites (and this sounds like a large site...) will have UPS systems installed to protect the LAN and Telecoms kit.
D7
25650[/snapback]
D7
25678[/snapback]
Sounds tough if every hub and switch is behind UPS. On the other hand if there is lack of UPS, Chris can sell them too.. :yes:
