hpotter Posted March 3, 2009 Posted March 3, 2009 After some further read, seems like the Scantronic 9751EN is the equivalent of the Galaxy G2-20And: 1-That it requires a Wireless module as an optional extra. 2- That it does not send SMS, but requires an additional advanced speechdialer to do that. So it is not impossible to get the Scantronic to do the Galaxy tricks, it just needs
Terry Posted March 3, 2009 Author Posted March 3, 2009 I have now two quotes: 1-From a local NSI Gold installer: G2-20 panel + MK7 keypad with prox & 5 fobs + 3 PIRs + 2 door contacts + External sounder + Internal sounder + decoy For
james.wilson Posted March 4, 2009 Posted March 4, 2009 id go for the gal. If you want voice as well as text then you will need to add a voice dialler to the gal however if your looking at monitoring then a voice dialler will probablly cause you issues (ie you will be on the phone to your dialler as the arc call you or try to, and they would have to move to the next keyholder. But as we have said before its not just about the equipment, you caould have the best equipment installe dbadly and you will have a bad system, much less an untidy one. Also you can installer lesser equipment well that would give a better system overall. Obviously you want the best equipment installed correctly. So dont make the decision purly on equipment and price. Who will give a better system overall? Thats what you need to be asking. Both panels (and you have only listed panel brands nothing else) are high quality units, but I am a Galaxy Fan. James securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
hpotter Posted March 4, 2009 Posted March 4, 2009 I know the 2nd quote is much more, TCO over say 10 yrs = 2nd quote cheaper (without seeing other T & C's) Q1 =
Terry Posted March 4, 2009 Author Posted March 4, 2009 TCO over say 10 yrs = 2nd quote cheaper (without seeing other T & C's)Q1 =
hpotter Posted March 4, 2009 Posted March 4, 2009 But would welcome your thoughts on these quotes though. I know the 2nd quote is much more, but I think it's because they had to add the SD2 at
Terry Posted March 4, 2009 Author Posted March 4, 2009 Reckon you answered your own question then. I kind of have yes. Going for the Galaxy with the 1st quote from the NSI gold supplier, as I discovered today the 12 months plan is a 0% plan; so can spread the cost over 12 months.
9651 Posted March 12, 2009 Posted March 12, 2009 Good choice imo We used to fit a lot of Scanny 9751's, but then after having a lot of glitches with the cheaper 9651, and the Menvier range for larger installs we moved to Galaxy and have not looked back. Having seen and worked on both panels extensively the G2-20 is way ahead in build quality. I have fitted well over 100 smaller 2-20/2-44 and never had a panel issue. Cant say that for Scantronic.......
Guest old-hand Posted March 12, 2009 Posted March 12, 2009 Good choice imoWe used to fit a lot of Scanny 9751's, but then after having a lot of glitches with the cheaper 9651, and the Menvier range for larger installs we moved to Galaxy and have not looked back. Having seen and worked on both panels extensively the G2-20 is way ahead in build quality. I have fitted well over 100 smaller 2-20/2-44 and never had a panel issue. Cant say that for Scantronic....... Funny we use both Cooper panels ( Scanny and Menvier, same company now) and Galaxy. Some have glitched some not in no particular order. Same as a new car some have faults some not. Lets go onto another panel shall we and really try to post more //.B.W.F.// about them.
9651 Posted March 12, 2009 Posted March 12, 2009 Funny we use both Cooper panels ( Scanny and Menvier, same company now) and Galaxy. Some have glitched some not in no particular order. Same as a new car some have faults some not. Lets go onto another panel shall we and really try to post more //.B.W.F.// about them. Seriously, the early 9651's had random tampers after ccts 4 onwards if using fsl...... Cooper denied it, then we got some 'modified' eproms to swap in glitching panels. I lost could the amount of M750s' M800's we had with no heartbeat, glitching E/E tones...., random masking/tamper faults caused by the plug on connectors.... Granted this is going back to the start of when the graded panels were released. Fingers well and truely burned, lost all confidence in thier product..... Had to be ditched. Was a shame as the TS range is/was brilliant, really rate the 2500, awesome bit of kit.
