Menvier Ts 700 - Keypad Problem
davidp
Guest old-hand
Last time I plugged in my engineers (TSNETLCD) keypad to a 700 it went nuts, just confirming that the newer style (Pre M) don't work on them!
:o
Dunno if the Starburst works on them though....
700 panels is as old as them there hills now!
Look on Ebay for a 900+ as the PCB will screw right in to the old box and work the existing keypads or newer ones.
LOL his keypads kerplucked.
Be easier to upgrade.
Got a TS690 available with a working keypad if I`m offered the right amount............Swaps out for a TS700.
He may want tags! 900+ will fit the box and is ok for a domestic DIY, dirt cheap on Ebay as well, new ones that is.
:rolleyes:
Just a thought (yes it hurt) it's not an onboard keypad is it?
My Amateur Radio Forum
Guest old-hand
:rolleyes:
Pmsl its a TS700 not a TS410.
no mate the 700 was ablank end station. SOlid panel too to be fair.
James, There is a Menvier panel in the same size box as the 700 with a keypad on it, it's about 20 years ago I saw it so I don't have 100% memory (nothing like it really!) of it.
It 'may' be a 800 but I just can't remember.
Oxo, is your meaty flavoured beverage too strong for you! Where did you get TS410 from!!!
:lol:
Guest old-hand
:lol:
From Cooper/Menvier site
These products are obsolete.
The TS400 and TS410 were 6 zone microprocessor based intruder alarm control panels with 5 programmable zones and a dedicated Final Exit zone. They were designed for domestic and smaller commercial installations.
TS400 Features
* 5 Programmable zones Night, Access, Fire, PA & Keyswitch (plus common tamper)
* Dedicated Final Exit zone
* On board keypad and LED indicators
* Up to 4 remote keypads
* Facilities to connect to an SD1 Speech Dialler
* 4 event log
* Programmable output for vibration detectors or latching PIRs
* Dual user codes
* Remote Reset facility
* 2.1 Ah battery capacity
* All data stored in Non-Volatile Memory (NVM)
Want to ask me about the 2500 now?
:P
:P
Yeah but why mention a 410? There are several on board keypad Menvier panels, but it's the TS800 that's in the same size box as the 700......
TS2500, got one fitted in my house!
It auto sets the shed at 2330 but has a tone on the timer set, I must look up how to silent set it!
:whistle:
Guest old-hand
Think you will find the TS800 and TS700 wont do the same box.
As for silent set on auto set, hehehe you need to know the trick for that one.
Ido!
Do you....? :rolleyes:
&00 and 800 were similar sized box, 410 et al were the small ones.
