pinter75 Posted March 3, 2009 Posted March 3, 2009 Howdy, Well I have my Scantronic 9000 back up and running sweetly with the help of the engineer manual and a good clean/recondition/replace of sensors etc. As this thing seems rock solid (they don't make them like this anymore), I would like to expand it's capabilities. I already have interfaced an autodialler to it but need some more features. Ideally I would like to add some more zones to it. I does have the 5-8 expander card, but I would like to fit a 9174 8 circuit board. Also I am looking out for a realy card (not sure on the model number). I need this because I am designing an add on microprocessor with LCD display and ethernet connection for web/sms notifications ) So if any of you installers have some old scanny gear in the corner of your store rooms, than you could help me out. I may be ok on the relay board, as there is one on eBay. eBay does seem good for old bits as I have a spare PCB and remote keypad already from there. .
Monty Posted March 4, 2009 Posted March 4, 2009 Good luck was a great panel in its day but think i would swap it out for a new M800/2000 now many more features and parts avalable if you get a problem , but hay good luck. www.AllanMoncrieffAlarms.com
Guest old-hand Posted March 4, 2009 Posted March 4, 2009 Sure you mean a 9100. Great little panel. Time to give up on it TBH. A M550 would be a good starter loads of features. Product name M550, M600 Security Grade PD6662: 2004, EN50131-1:2006, TS50131-3:2003, EN50131-6:1997, Grade 1, or 2. DD243:2004. Sales number M550/M600 Product Description 40 Zone Grade 2 Panel without comms (M500) / with comms (M600) Capacities Max zones 40 Zones - on board 8, CC or FSL Zones - on expander(s) 32 Standard wired outputs - on board 3 Communicator outputs: 8 Outputs on expander module(s) None Setting Levels: Full set for each ward Partitions: 4 Log capacity (events): 1000 No. Keypads 16 max Internal Clock
pinter75 Posted March 4, 2009 Author Posted March 4, 2009 As for changing the panel see http://www.thesecurityinstaller.co.uk/comm...showtopic=27332
Guest old-hand Posted March 4, 2009 Posted March 4, 2009 As for changing the panel see http://www.thesecurityinstaller.co.uk/comm...showtopic=27332 As stated a great panel, but nothing lasts forever.
