Sd1+/optima Compact
amicus
A panel with specific dialler outputs would be better but the SD1 is designed to work with either a switched negative or positve output so it really should work.
The strobe output is a switched negative. If there is no strobe fitted then it should be fine, if there is a strobe fitted try connecting the SD1 along with the strobe. If the strobe continues to run after you turn the alarm off and reset it (because the strobe output stays low until you do a reset with this panel) connect the strobe along with the sounder and use the strobe output to run the SD1.
Finally if none of this works use the bell output to drive the coil of a 12volt relay, use the contacts of the relay to fire the dialler.
Thanks for this information,i will try these on my next visit.
