lowlofe Posted March 9, 2009 Posted March 9, 2009 Hi there, Where would i be able to get hold of new smoke cloak fluid, for a system 4000, plus i am installing the unit in a attic over the main stair way up the entire building, but how would you suggest i get the fog stream from going sideways in the attic to going down through the ceiling, we are talking a distance of less than a foot, but is there any special ducts that should be used, regs alex
Guest RJBsec Posted March 9, 2009 Posted March 9, 2009 Speak with smokecloak - and be aware of the need for adequate insurance to have one installed in your property, I assume that you don't have that.
Amps Posted March 9, 2009 Posted March 9, 2009 plus i am installing the unit in a attic over the main stair way up the entire building, but how would you suggest i get the fog stream from going sideways in the attic to going down through the ceiling, we are talking a distance of less than a foot, but is there any special ducts that should be used,regs alex Cut a length of drainpipe to suit
lowlofe Posted March 9, 2009 Author Posted March 9, 2009 Ahh i dont have the insurance, i know you have to show signs at normal entry points of the building, i just thought that was it pluss will drain pipe do the job?? because i thought the smoke would be hot? regs alex
SUBS Posted March 10, 2009 Posted March 10, 2009 You'l probably find that if an intruder falls down the stairs due to the poor visibilty, while carrying his swag bag full of someone elses valuables. Some do gooder will help him sue you free of charge and you'll end up keeping him for the rest of his days !
chexsec Posted March 10, 2009 Posted March 10, 2009 Where would i be able to get hold of new smoke cloak fluid, for a system 4000, Speak to Ricky Beal at Smokecloak tel 01604 839000 will drain pipe do the job??because i thought the smoke would be hot? You can use any flexible or fixed ducting. Drainpipe is ideal because it's cheap and don't worry about the temperature, once the liquid vapourises it is barely warm.
lowlofe Posted March 11, 2009 Author Posted March 11, 2009 Speak to Ricky Beal at Smokecloak tel 01604 839000You can use any flexible or fixed ducting. Drainpipe is ideal because it's cheap and don't worry about the temperature, once the liquid vapourises it is barely warm. Sorted! Thankyou for your help guys! A true asset to the forum! regs alex
