crop Posted March 10, 2009 Author Posted March 10, 2009 The ladies were amateurs at wallpapering but he was a carpet fitter(thats his job) I wonder how many cables he has cut in his career.
lawandorder Posted March 10, 2009 Posted March 10, 2009 The ladies were amateurs at wallpapering but he was a carpet fitter(thats his job) I wonder how many cables he has cut in his career. Well I would be tempted to bin the panel but if you have the motivation/ energy/inclination it might be worth disconnecting the keypad then wire it directly to the panel using a short length of cable, also disconnect all other devices. Put links in the tamper circuits including the bell tamper then try again. If this fails you can be pretty sure you have a duff panel.
Guest old-hand Posted March 10, 2009 Posted March 10, 2009 Well I would be tempted to bin the panel but if you have the motivation/ energy/inclination it might be worth disconnecting the keypad then wire it directly to the panel using a short length of cable, also disconnect all other devices.Put links in the tamper circuits including the bell tamper then try again. If this fails you can be pretty sure you have a duff panel. QFA Flylead and check and test.
crop Posted March 10, 2009 Author Posted March 10, 2009 Thanks a lot, i had already told them that i was probably going to dissconnect everything and start from scratch 1 circuit at a time, i suppose thats the way it has to be. thank you all for your comments.
Guest RJBsec Posted March 10, 2009 Posted March 10, 2009 Time versus cost of new panel - still say bin it and save your time.
y-i-out-of-bed Posted March 12, 2009 Posted March 12, 2009 new accenta g4 strate swap job done scruw fix about
crop Posted March 17, 2009 Author Posted March 17, 2009 As i have the time i will go through the motions for her but will keep in mind the new panel. thanks
y-i-out-of-bed Posted March 17, 2009 Posted March 17, 2009 hum in that case i would take keypad to the panle as sergested also link out all zones and tampers and try old code & default code if you have installer manual dono if i can give you code or how to get to eng but sure that some thing that old sould be out there someware also if you have data and sound cores the wrong way round it will stop working so cheak these are ok also day and power wont show as it is in alarm these will come back when code is entererd cheack amps going to keypad and bellbox and all detectors. is there any burns on mainboard as some times a short on sounder can damage board.
