Scantronics 9751
hazey
Have just installed this, but can't get it out of installer mode when I apply the power. It keeps complaing about the tamper on zones 1 to 8. I have placed a wire jumber across the two tamper connectors, but it still has the same fault. Any ideas what I am doing wrong?
Many thanks
H.
A quick test for the zones not being used go into zone progg and progg them as not used and remember to link out your 0 volts to Tr you should then be able to leave eng mode.
www.AllanMoncrieffAlarms.com
if u r not using resistors then opt 21 change it to two wires(press 1or2) if i remember right!
The system is set up with 4 wires and a common tamper, so no resistors to fiddle with. Have checked the option 21 and it is still set as the default of 0 - closed circuit + com A/T. Have used all 8 zones to nothing to set to not used......I did have a fault with the bell anti tamper - but that went away when I actually conneced the bell DOH! (Did not want to upset the neighbours too quickly)
I think my next plan is to take all the wiring to bits and add in a zone at a time and check it each time - unless there are more good ideas out there.
Thanks for the help so far
Hazel
So you have a wire link in the A/T terminals, one from the 0v to t and have the lid shut when powering up yes?
tamper zones 1-8 means global tamper, which is the A/T connection only....
Dont't have a wire from 0v to T yet, but may try it later. The only jumper I have in is on the global anti tamper circuit, and when I put a continuity tester over the connectors I got a circuit (even without the jumper) - always test with the lid on to avoid the box anti tamper setting it off. Will keep you posted.
H.
