4 Wire Grade 2
Could somebody please clear this up for me please, is it ok to four wire detectors on a grade 2 system or must it be e.o.l. <_<
either / both comply
I believe it is OK to use double pole on Grade 1 and 2 systems.
We use FSL for Grade 2 and 3.
Trade Member
  steveo44 said:
Fast answers :) That sorted then, ta.
What's FSL though?
fully supervised loop ...... same as eol
Beg to differ, sorry. fsl has an end of line for tamper + another series for alarm.
Sorry, grandma, eggs etc....
Yes, you're right .... the only way we do eol/fsl is the fsl way, so I forgot about the single resistor methods of eol
To add to the original question, are global tampers acceptable for grade 2 ? steamingcup
