niceicman Posted March 12, 2009 Posted March 12, 2009 Hi guys Some help please I am installing a fire alarm system to a old building which is flats and has been for the past 30 years , which is owned by the council Now was going to install and category L3 Can install addressable or conventional generally ctec with Apollo heads Which are sounders break glasses smoke detectors in communal hallways and stairwells And smoke detectors in hall of flat and heat detectors in kitchen Now the problem I have will be false alarm IE the drunk in flat 3 comes in drunk and sets off the panel as he has burnt his toast The system is screaming ect All tips accepted Thanks for reading past
A-G Posted March 12, 2009 Posted March 12, 2009 Please take this the right way. If you are asking these questions ..... you should not be designing this alarm. You may well be the best guy in the country at installing, but designing the system is a different skill set and if it is wrong people could die. .... nothing else to say . . . . PM me for access to the SSAIB members discussion area.
steven sneddon Posted March 12, 2009 Posted March 12, 2009 Hi guys Some help please I am installing a fire alarm system to a old building which is flats and has been for the past 30 years , which is owned by the council Now was going to install and category L3 Can install addressable or conventional generally ctec with Apollo heads Which are sounders break glasses smoke detectors in communal hallways and stairwells And smoke detectors in hall of flat and heat detectors in kitchen Now the problem I have will be false alarm IE the drunk in flat 3 comes in drunk and sets off the panel as he has burnt his toast The system is screaming ect All tips accepted Thanks for reading past First things first, are you installing to L3 on your own initiative or is this the recommendation from your clients official fire risk assessment? think I was a bit late there AG
niceicman Posted March 12, 2009 Author Posted March 12, 2009 Please take this the right way.If you are asking these questions ..... you should not be designing this alarm. You may well be the best guy in the country at installing, but designing the system is a different skill set and if it is wrong people could die. .... nothing else to say . the recommendation from my clients official fire risk assessment know i am am anewbie but alarm guard you are a sma-t XXXX just a spark useing the forum for help wich i thort we all helped each other i work for a firm and they desigin it
A-G Posted March 12, 2009 Posted March 12, 2009 but alarm guard you are a sma-t ars-e No I'm not, and I resent you saying so. Take a look at my other posts ... I don't seek to belittle people, but you need to know the gravity of the situation .... and if you don't believe me take a look at BS5839 and see who should design the fire detection system. . . . PM me for access to the SSAIB members discussion area.
MatonTE1 Posted March 12, 2009 Posted March 12, 2009 Is the system to be to the recommendations of Part 6 or to Part 1?If it is to Part 6 what grade has been recommended to determine L3 (or LD3 as it is)? Allen
Guest RJBsec Posted March 12, 2009 Posted March 12, 2009 the recommendation from my clients official fire risk assessmentknow i am am anewbie but alarm guard you are a sma-t ars-e just a spark useing the forum for help wich i thort we all helped each other i work for a firm and they desigin it I see you are out to make friends If your firm has designed the system why not put your concerns to them and ask them how they want it overcome?
MatonTE1 Posted March 12, 2009 Posted March 12, 2009 the recommendation from my clients official fire risk assessmentknow i am am anewbie but alarm guard you are a sma-t ars-e just a spark useing the forum for help wich i thort we all helped each other i work for a firm and they desigin it If your company designed the system then they will have taken into account any potential false alarms and given a solution for same. You'll find if you give as much info at the start then people won't take the wrong end of the stick.
luggsey Posted March 12, 2009 Posted March 12, 2009 Hi guys Some help please I am installing a fire alarm system to a old building which is flats and has been for the past 30 years , which is owned by the council Now was going to install and category L3 Can install addressable or conventional generally ctec with Apollo heads Which are sounders break glasses smoke detectors in communal hallways and stairwells And smoke detectors in hall of flat and heat detectors in kitchen Now the problem I have will be false alarm IE the drunk in flat 3 comes in drunk and sets off the panel as he has burnt his toast The system is screaming ect All tips accepted Thanks for reading past It's possible to program some systems to delay sounders in all areas, just activate sounders in area/floor local to the alarm then to attempt an auto reset, if this is successful then all goes quiet, if the alarm activates again withing a few seconds then a full alarm is initiated and the building evac'ed. This sort of programming allows for the 'burnt toast' unwanted alarms which are quickly sorted out by the flat owner by opening the doors and flapping a towel around. All subject to a RA and possibly agreement of the fire officer. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Adi Posted March 12, 2009 Posted March 12, 2009 It's possible to program some systems to delay sounders in all areas, just activate sounders in area/floor local to the alarm then to attempt an auto reset, if this is successful then all goes quiet, if the alarm activates again withing a few seconds then a full alarm is initiated and the building evac'ed. This sort of programming allows for the 'burnt toast' unwanted alarms which are quickly sorted out by the flat owner by opening the doors and flapping a towel around.All subject to a RA and possibly agreement of the fire officer. ctec panel will do that I really can't be ar**** with it anymore.
