luggsey Posted March 13, 2009 Posted March 13, 2009 I'll give him your best wishes shall I .. B) You can give him my cold if you like! ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Guest RJBsec Posted March 13, 2009 Posted March 13, 2009 You can give him my cold if you like! You too, I'm on Lemsip rather than shiraz!
luggsey Posted March 13, 2009 Posted March 13, 2009 Wimps................................... Say that to my face big man and I'll knock you down with just one sneeze! You too, I'm on Lemsip rather than shiraz! I hit the port, big time. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Stewbow Posted March 14, 2009 Posted March 14, 2009 Hi guys Some help please I am installing a fire alarm system to a old building which is flats and has been for the past 30 years , which is owned by the council Now was going to install and category L3 Can install addressable or conventional generally ctec with Apollo heads Which are sounders break glasses smoke detectors in communal hallways and stairwells And smoke detectors in hall of flat and heat detectors in kitchen Now the problem I have will be false alarm IE the drunk in flat 3 comes in drunk and sets off the panel as he has burnt his toast The system is screaming ect All tips accepted Thanks for reading past The LACORS Guidance document http://www.lacors.gov.uk/lacors/upload/19175.pdf tells you that you should not have a smoke detector inside the hallway of the flat that is linked to the main alarm system. It should be a Heat Detector, which shouldn't be set off by the late night toast maker. You need to install a mixed system, a grade A LD2 and a grade D LD3 This would require a mains powered smoke detector also in the hallway inside the flats, that would be exlusive to that individual flat. The theory being that if toast is burnt, only the people in that flat will hear the "false alarm" LONG LIVE RAFIKI !!!!!!!!!!
MatonTE1 Posted March 14, 2009 Posted March 14, 2009 The LACORS Guidance document http://www.lacors.gov.uk/lacors/upload/19175.pdf tells you that you should not have a smoke detector inside the hallway of the flat that is linked to the main alarm system. It should be a Heat Detector, which shouldn't be set off by the late night toast maker. You need to install a mixed system, a grade A LD2 and a grade D LD3 This would require a mains powered smoke detector also in the hallway inside the flats, that would be exlusive to that individual flat. The theory being that if toast is burnt, only the people in that flat will hear the "false alarm" LONG LIVE RAFIKI !!!!!!!!!! Rafooki more like!
DirectFS Posted March 14, 2009 Posted March 14, 2009 Rafunkamidoingusingthisagaini. RafeelanupgradecomingonagainQUICKI! Rawouldn'tuseitifitwasfree Just a few terms heard in favour of our friends at R****i. Bill. Rafooki more like! Bill Accord Fire & Security Services Ltd. www.accordfire.co.uk ~ TEL: 0845 474 5839
luggsey Posted March 14, 2009 Posted March 14, 2009 Rafunkamidoingusingthisagaini.RafeelanupgradecomingonagainQUICKI! Rawouldn'tuseitifitwasfree Just a few terms heard in favour of our friends at R****i. Bill. Do you work for Rafiki tech support? ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
james.wilson Posted March 14, 2009 Posted March 14, 2009 well i like it seriously i do for the right jobs securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
MatonTE1 Posted March 14, 2009 Posted March 14, 2009 well i like it seriously i do for the right jobs Some people like fugu but it's not for me.
