sdotjee Posted March 13, 2009 Posted March 13, 2009 im replacing the battery in my panel(aritech) and im going to tidy it up while im at it ,someone wired it as a mess,but working.....im wondering whats the best way to join all the 12v supplies...there are 12 pirs to join up and supply....they were just twisted together and taped!!!!!!!!!!! maybe soldering and heatshrink the lot with .75 flex tails to the +ve and -ve terminals???? an experienced opinion would be appreciated!
ian.cant Posted March 13, 2009 Posted March 13, 2009 Connector block, then if you have to take them apart for some reason you dont have get the soldering iron out.
lawandorder Posted March 13, 2009 Posted March 13, 2009 Connector block, then if you have to take them apart for some reason you dont have get the soldering iron out. Either way is good but as ian says connector blocks make it easier to seperate in future.
georgahti Posted March 13, 2009 Posted March 13, 2009 was going to type something but decided not to (as i recalled UK type alarm cable..)...
