jamie473 Posted March 15, 2009 Share Posted March 15, 2009 I installed an ESP Infinite Wireless Alarm about a year ago and up until recently it's behaved perfectly. Now every couple of days it false alarms even when not armed. It's not choosy about the time of day this happens, in fact it happened just 5 minutes ago! The control panel is not reporting low batteries in any of the PIR's or the external siren, which is why the bahaviour is baffling me. Any ideas or areas to check? Link to comment Share on other sites More sharing options...
georgahti Posted March 15, 2009 Share Posted March 15, 2009 I installed an ESP Infinite Wireless Alarm about a year ago and up until recently it's behaved perfectly. Now every couple of days it false alarms even when not armed. It's not choosy about the time of day this happens, in fact it happened just 5 minutes ago! The control panel is not reporting low batteries in any of the PIR's or the external siren, which is why the bahaviour is baffling me. Any ideas or areas to check? did you check the log? could be just RF interference from neighbors new wireless doorbell etc.. or someone jamming (with the mentioned doorbell) your alarm until you power it down and then burgle you. Link to comment Share on other sites More sharing options...
Guest RJBsec Posted March 15, 2009 Share Posted March 15, 2009 What does the panel report when you enter your code to switch off? What is shown in the log? (Don't worry about George's paranoia!) Link to comment Share on other sites More sharing options...
georgahti Posted March 15, 2009 Share Posted March 15, 2009 did you check the log? What does the panel report when you enter your code to switch off?What is shown in the log? see - we also agree on things. we only debate about the wireless/wired detector to panel connections (as far as i can remember). Link to comment Share on other sites More sharing options...
jamie473 Posted March 15, 2009 Author Share Posted March 15, 2009 Going through the log there are three instances of 'Tamper: External Siren' amongst the usual events like arm/disarm! Link to comment Share on other sites More sharing options...
Guest RJBsec Posted March 15, 2009 Share Posted March 15, 2009 Going through the log there are three instances of 'Tamper: External Siren' amongst the usual events like arm/disarm! There's your problem: Front cover expanding in the sun causing interrmitent tamper fault.Rear tamper ditto, (if fitted).Water ingress caused component damage. Whatever needs the ladder out to check - if you're doing it e careful! Link to comment Share on other sites More sharing options...
