alterEGO Posted March 15, 2009 Posted March 15, 2009 I have rubber slippers..........................GIT make sure they are wet then
A-G Posted March 15, 2009 Posted March 15, 2009 I can plug in my shaver and have a hot/cold tap running in the other.................. Ah, if it's a double insulated shaver socket, that's different again. . . . PM me for access to the SSAIB members discussion area.
luggsey Posted March 15, 2009 Posted March 15, 2009 Bathrooms are 'zoned' and certain equipment cannot be installed in these zones. If the heater and switch are out of the zone then it 'may' be ok depending on the RCD fitted, to have them in the bathroom. As a rule I never fit plate switches in a bathroom and only ever use pull switches. In a large commercial spa room we once fitted a double socket because it was way out of zone allowing for a 2m cord on appliances. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Woosh Posted March 15, 2009 Posted March 15, 2009 Agree with Luggsey if its out of the zone you can have a socket outlet !!
Guest old-hand Posted March 15, 2009 Posted March 15, 2009 Ah, if it's a double insulated shaver socket, that's different again. Yeah I know, was messing. make sure they are wet then laugh.gif Always
ispy Posted March 16, 2009 Posted March 16, 2009 the 17th edition now allows for socket outlets other than selv to be permitted in zone 3 of a bathroom provided the circuit is RCd protected. However the work comes under Part P as it is a special location! ve hav ze nolij or if not we ask!!!!
hpotter Posted March 16, 2009 Author Posted March 16, 2009 the 17th edition now allows for socket outlets other than selv to be permitted in zone 3 of a bathroom provided the circuit is RCd protected. However the work comes under Part P as it is a special location! Ahhh. Hence other flats new fuseboard. Thanks ispy.
Paul P Posted March 17, 2009 Posted March 17, 2009 the 17th edition now allows for socket outlets other than selv to be permitted in zone 3 of a bathroom provided the circuit is RCd protected. However the work comes under Part P as it is a special location! 17th edition does not have a zone 3 only 1&2. Sockets must be 3 meters from zone 2 Trade Member
justin Posted March 18, 2009 Posted March 18, 2009 17th edition does not have a zone 3 only 1&2. Sockets must be 3 meters from zone 2 Sockets must be 3m from zone 1 (edge of the bath) and protected by 30ma RCD. Not allowed in my house though. Never.
