y-i-out-of-bed Posted March 24, 2009 Posted March 24, 2009 yeap follow the links these will help you, did he give you a user guide?
y-i-out-of-bed Posted March 24, 2009 Posted March 24, 2009 quick guide based on mx4 press prog enter your code day + tamper now show then these will do the following 8 to change code 1234 light up put in new code then beep beep day + tamper show again press 0 to take you in to tests menu, day + tamper + attack now show each one at a time use 0 to get out 2= strobe 3= bell 4=speaker test 2 then 4=loud speaker test 5=walk test (this will beep as each zone is tested) on all once done press 0 to go back to exit press reset twice or intill tamper attack dont show hope this helps though a pro will get this done in no time and should be able to test battory, also count with insurance if pro dose service and it is set every time you leave enjoy your trip
