aptsys Posted April 1, 2009 Posted April 1, 2009 Can't say I've had any issues with the USB Com causing odd behaviour in any panels I've fitted. Perhaps you have a faulty lead?
Fred555 Posted April 1, 2009 Posted April 1, 2009 Can't say I've had any issues with the USB Com causing odd behaviour in any panels I've fitted. Perhaps you have a faulty lead? What I will now clarify again is that - I have noted that if you plug a USB COM into a Premier and then power up that Premier from stone cold then the COM 2400 will not work - and a few other things also behave incorrectly - (until you unplug USB COM - switch everything off completely and apply power again - everything is then fine) therefore have not done this (leaving USB COM connected to Premier on start up) since version 5 (I think) Premier and have been happily plugging and unplugging USB COM (but only on Premiers running normally at tick over - not when starting up) since then with no issues whatsoever - I cannot make the point any clearer.
