Driller Posted March 20, 2009 Share Posted March 20, 2009 I had intended to buy a couple of these for inside use and remote night veiwing but I see that they are no longer to be found on the Techwin site (unless yuo do a search). Have they been pulled? Is there something wrong with them? I thought they looked pretty good and have only heard good things about them. Alpat Systems? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27748-whats-happened-to-the-sir-4250s/ Share on other sites More sharing options...
Alpat Systems Posted March 20, 2009 Share Posted March 20, 2009 I had intended to buy a couple of these for inside use and remote night veiwing but I see that they are no longer to be found on the Techwin site (unless yuo do a search).Have they been pulled? Is there something wrong with them? I thought they looked pretty good and have only heard good things about them. Alpat Systems? Mmm, just checked and see what you mean. I've not heard there being pulled, they may be doing an updated version. Worth given Norbain or Dynamic a call, they may be able to shed some light on things. EDIT......just checked and it has been discontinued together with the SIR-4150 as well. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27748-whats-happened-to-the-sir-4250s/#findComment-229906 Share on other sites More sharing options...
Driller Posted March 20, 2009 Author Share Posted March 20, 2009 Damn, I was really interested in those. I think my supplier will still be able to get hold of some (along with the svd4600's I'm getting) but why would they have been discontinued? Did they not sell well and if not why not... Could you suggest an equivalent indoor IR dome with similar or better performance? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27748-whats-happened-to-the-sir-4250s/#findComment-229934 Share on other sites More sharing options...
Alpat Systems Posted March 20, 2009 Share Posted March 20, 2009 Damn, I was really interested in those. I think my supplier will still be able to get hold of some (along with the svd4600's I'm getting) but why would they have been discontinued?Did they not sell well and if not why not... Could you suggest an equivalent indoor IR dome with similar or better performance? I'm guessing that with the release of the 4th generation DSP chipset, the need for an IR internal dome camera isn't required. The 4250 was aimed at a niche market, mainly night clubs. It was internal only (no IP rating), and no vandal resistance. In saying that Samsung may release an alternative......... Off the top of my head I cant think of an IR internal dome thats an alternative, I'm just about to leave the office but I'll have a look on Monday. I'm pretty sure Norbain will still have some in stock. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27748-whats-happened-to-the-sir-4250s/#findComment-229993 Share on other sites More sharing options...
Driller Posted March 23, 2009 Author Share Posted March 23, 2009 I'm guessing that with the release of the 4th generation DSP chipset, the need for an IR internal dome camera isn't required.The 4250 was aimed at a niche market, mainly night clubs. It was internal only (no IP rating), and no vandal resistance. In saying that Samsung may release an alternative......... Off the top of my head I cant think of an IR internal dome thats an alternative, I'm just about to leave the office but I'll have a look on Monday. I'm pretty sure Norbain will still have some in stock. OK, but by the sound of it they are not bad cameras as such, just without a huge market. Did you manage to find an equivalent? I've been looking at the new SID460 and wondered that if their 0.0006 lux abilities they would be sufficient for internal night viewing with street lighting filtering through the windows. Which one of the two would you use AlpatSystems? SID460(or 560) or SIR4250? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27748-whats-happened-to-the-sir-4250s/#findComment-230433 Share on other sites More sharing options...
Alpat Systems Posted March 24, 2009 Share Posted March 24, 2009 OK, but by the sound of it they are not bad cameras as such, just without a huge market. Did you manage to find an equivalent?I've been looking at the new SID460 and wondered that if their 0.0006 lux abilities they would be sufficient for internal night viewing with street lighting filtering through the windows. Which one of the two would you use AlpatSystems? SID460(or 560) or SIR4250? For the situation your describing, I'd go with the 4250. Although the SID-460 will do 0.0006Lux, and even with the 4th gen chipset you'll still experisnce image ghosting with no additional light source. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27748-whats-happened-to-the-sir-4250s/#findComment-230615 Share on other sites More sharing options...
Driller Posted March 24, 2009 Author Share Posted March 24, 2009 For the situation your describing, I'd go with the 4250.Although the SID-460 will do 0.0006Lux, and even with the 4th gen chipset you'll still experisnce image ghosting with no additional light source. Thanks for the info. I'll go with the 4250 then. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27748-whats-happened-to-the-sir-4250s/#findComment-230616 Share on other sites More sharing options...
Alpat Systems Posted March 27, 2009 Share Posted March 27, 2009 Looks like the new range of cameras are due shortly..... Samsung Electronics is set to unveil its new generation A1 series of CCTV cameras at IFSEC Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27748-whats-happened-to-the-sir-4250s/#findComment-230948 Share on other sites More sharing options...
digitalwitness Posted March 27, 2009 Share Posted March 27, 2009 Samsung Techwin and Samsung Electronics are two different companies, think the originator was referring to techwin cameras. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/27748-whats-happened-to-the-sir-4250s/#findComment-230950 Share on other sites More sharing options...
