Guest Sales Posted July 11, 2004 Posted July 11, 2004 Hi We have a veritas Alarm installed 1998, the co that installed has dissappeared keep having intermitting problem with alarm going off, says one of the zones, but on checking no spiders or problems Any Ideas South Manchester based
Guest Guest Posted July 11, 2004 Posted July 11, 2004 Hi RichL husband tried to re-position contact in bethroom alarm going off any ideas how to stop and how do we change battery thanks
Guest Guest Posted July 11, 2004 Posted July 11, 2004 oops update the alarm has stopped and no matter what still in unset mode any ideas
Mister_Dave Posted July 11, 2004 Posted July 11, 2004 If you just enter your code when the alarm goes off. Make sure the contacts are connected properly. To change the battery switch off the mains to the panel open it up ( tamp alarm will go off ) enter your code, change the battery close the panel make sure it sets / unsets. Job done. Dave Oxendale York based security systems engineer.
Guest Guest Posted July 11, 2004 Posted July 11, 2004 hi all the pir are not lighting up and the beeper is not soundsing and the power light is still on and no matter what we hit nothing will set
Guest Guest Posted July 11, 2004 Posted July 11, 2004 sorry also husband turned power off and let alarm reset on own after me hitting every button and combination any ideas just to get it up and working again would be a help and then we can find an engineer in south manchester to sort it out
Mister_Dave Posted July 11, 2004 Posted July 11, 2004 have you had any work done to the system wiring latley. Dave Oxendale York based security systems engineer.
morph Posted July 11, 2004 Posted July 11, 2004 Did the alarm work correctly before he started? If yes, then it is most likely that he has got the wiring wrong. If you know what zone number it is then have a look in the panel and see what colour the wires are that are connected to on that zone. Then in the conatct the two wires should each be connected to one of the two silver screws respectively. There may also be a tamper circuit, in the panel follow the two wires from the zone until you find the white sheaf of the cable there will be two other wires going to the tamper circuit, possibly in a loop with the other detectors. Go back to the contact and twist these two wires together on one of the brass screws and refit the contact. You also need to make sure that the contact is aligned correctly and that the gap between them is not too big. they should not be touching(3mm gap) Now try the alarm. If the fault was existing then it would be easier to get a proffessional in to fix. When did you last change the batteries in your alarm. Colin.
morph Posted July 11, 2004 Posted July 11, 2004 If you want an engineer give Tony at "Boss Alarms" a call he will be able to help you out, his number is 01457-835859. Colin.
Guest Guest Posted July 11, 2004 Posted July 11, 2004 Hi Guys thanks for your infor- read to husband, hes not changed wiring he just unscrewed a window contact checked the wiring and resrewed it back then hell let loose he said LED lights havent lit up and it looks like a pwer failure ( he turned it off) power light on perm need an engineer in south manchester- any recc any other ideas to re-set apart from a hammer
