Tflynn Posted March 23, 2009 Posted March 23, 2009 Hi all New to this and want some advice on which is the best premicell to use with an ISDN equipped BT Versatility? I have 1 ISDN line connected and have a spare ISDN card in the CCU. I want to route all mobile calls through the premicell. Thanks for the help in advance, Trevor
Lectrician Posted March 24, 2009 Posted March 24, 2009 I have personally not seen an ISDN premicell, just PSTN. The line ports you have on the Versatility can be either ISDN or PSTN depending which module you install in the slot. ISDN are red and PSTN are black. You can have line 1+2 as the ISDN circuit, and then use line 3+4 for the PSTN. You would then program line 4 as un-equipped. Line 3 would be your PSTN premicell. A black PSTN module is far more expensive than a red ISDN. A quick google does suggest that ISDN Premicells do exist. Rather costly though, and you cannot un-equip 'half' of a versatility ISDN access. Email : martin@askthetrades.co.uk
Tflynn Posted March 24, 2009 Author Posted March 24, 2009 Yes I gathered that I would have to buy an analogue line port for the Versatility and use that for connection to the premicell. By going ISDN I would run into problems with line 4 as you say I could not disable that only the pair. So what brand of premicell would you recommend?
Lectrician Posted March 24, 2009 Posted March 24, 2009 When you said you had a spare ISDN card I assumed you meant you wanted to use ISDN. Erricson and NEC seem to be the leading brands, but I am sure they are all pretty similar. Email : martin@askthetrades.co.uk
Tflynn Posted March 24, 2009 Author Posted March 24, 2009 Thanks Martin is it? I can buy an analogue card as suggested and connect the premicell to this. In a nutshell are they straight forward to connect and configure?
Lectrician Posted March 24, 2009 Posted March 24, 2009 Thanks Martin is it?I can buy an analogue card as suggested and connect the premicell to this. In a nutshell are they straight forward to connect and configure? Very easy to connect, and as long as you have a sim card and contract/pay as you go, easy to setup. No issues to look out for other than the obvious - make sure you place the premicell away from electronic kit (including the PBX or any amps connected to it)......You know what it is like when you put a mobile near your stereo....... Email : martin@askthetrades.co.uk
Woosh Posted March 24, 2009 Posted March 24, 2009 I have two Nokia premicells for sale if anyone is interested PM me.
