Guest Spencer Thompson Posted July 11, 2004 Posted July 11, 2004 I have an Optima XM6 Panel and the keypad flat ribbon has deteriorated so the keypad no longer works. Is it possible to get a spare keypad? I appreciate that it is probably not possible.... With that in mind what would be a suitable alternative panel to fit, I have had a look around and there are quite a few for around £40. Which would people recommend if they were having a replacement themselves...
DGMarsden Posted July 11, 2004 Posted July 11, 2004 If you want to stick with the familiarity then stick with the optima G3 range as it works the same way as what you are used to and is really reliable. If you fancy a change try the texecom veritas range or the eurosec as reccomended by pete. Dave
Steve K Posted July 12, 2004 Posted July 12, 2004 Texecom Veritas 8 will be a good replacement with similar features. A bit cheaper than the G3 range. Steve Steve Kendall Plymstock Security Systems CCTV, Intruder Alarms, Security Lighting & Access Control Covering Plymouth, Plymstock, Plympton, South Devon and South East Cornwall
