Scantronic 9800 Extension Speaker
Hi there,
I've got a Scantronic 9800 to which I've fitted two extension speakers (CQR Mach 1 16ohm). The Scantronic manual states that two speakers can be fitted, I've connected them in series (giving a 32ohm load). They work fine but......I can't adjust their volume to lower the entry / exit tone, I've turned the potentiometer on the control pcb to both extremes and it seems to make no difference.
Any advice please?
Stoaty
For a start, none of the 9800's I have worked on have a volume pot. What you have probably adjusted is a factory set potentiometer (usually to do with the voltage regulator circuit) that is not supposed to be adjusted once it's been set at the factory, end user or service engineer alike!
Also, the speaker on the 9800 will only signal alarm (tamper, alarm, fire, fail to set) and chime tones, not entry exit tones.
Trade Member
Wasn't this query about the 2 CQR extension speakers and not the 9800 one??
Must admit I didn't think they had either but checking the manual it seems that the 9800+ does have a volume pot.
I'm guessing either the OP has a 9800+ or he has indeed adjusted something else.
You are also right about entry/exit tones on the 9800 only coming from the keypad but again on the + they came from the speaker as well (according to the manual).
I have never actually worked on a 9800+, it came out in the face of some very stiff competition from Menvier and I used TS 900s.
Yes but the 9800 didn't actually have a built in speaker so I think we are all talking about the extension ones.
Never seen 98+, but hopefully that's what the OP has, though I get the feeling it's the standard 98 as his volume pot does'nt seem to be doing anything :fear:
What? 2 extention speakers connected to a 9800 panel :rolleyes:
Trade Member
Know nowt about it but was only quoting from the original post.
Guest RJBsec
Compatible Equipment
9825 Remote Keypad
9827 Remote Keypad
9040 Internal loudspeaker (16 Ohm). 2 max, fit at least one.
9056 Plug-on Digital Communicator
9076-01/02 Signalling Relay Interface
960 Speech/Digital Communicator
9066 Self-Activating Bell (SAB) Module
