funster Posted March 28, 2009 Posted March 28, 2009 Hi All, I have a gartec 501, and I have forgotten the engineer code. However I do have a 7yd skip on my drive, and somewhere near the bottom is a box with the codes in it....... to save me having to empty said skip is there any way to reset it? I have tried the default reset but as it did not work I must have started it with a 9. Any ideas or is it new panel time? Thanks in advance. PLEASE NOTE ITS A 580 NOT 501 BUT I CANT EDIT THE TITLE FOR SOME REASON
lawandorder Posted March 28, 2009 Posted March 28, 2009 Hi All,I have a gartec 501, and I have forgotten the engineer code. However I do have a 7yd skip on my drive, and somewhere near the bottom is a box with the codes in it....... to save me having to empty said skip is there any way to reset it? I have tried the default reset but as it did not work I must have started it with a 9. Any ideas or is it new panel time? Thanks in advance. If your code was only 4 digits and you know it starts with a particular number then you only have 1000 differs, not as bad as it sounds once you get into a rythmn! Beyond that site rules prohibit giving out default information.
funster Posted March 28, 2009 Author Posted March 28, 2009 If your code was only 4 digits and you know it starts with a particular number then you only have 1000 differs, not as bad as it sounds once you get into a rythmn!Beyond that site rules prohibit giving out default information. Ok thanks for that, might give it a try just need to work out if its easier to empty the skip........lol
lawandorder Posted March 28, 2009 Posted March 28, 2009 Ok thanks for that, might give it a try just need to work out if its easier to empty the skip........lol It really isn't as bad as it sounds, just start at *00, *001, *002 etc etc....... I'd rather do that than empty a skip!
funster Posted March 28, 2009 Author Posted March 28, 2009 It really isn't as bad as it sounds, just start at *00, *001, *002 etc etc.......I'd rather do that than empty a skip! Yep done it thanks......... and it was a memorable number!!! just reconfigured to start with a 9. But every time I went to the skip, I just looked and thought.....NO. Anyway thanks for that. Funster
