12v Cable connectors
Guest tanknet
yes getting there BUT the ones i have have clear centres not orang ones
Same difference. You're just being a pita now.
This is what your after
http://www.comtec-comms.com/documents/pg%2...comtec%20tc.pdf
The real name for these are Wire connector 8A-1 from BT
If your connecting a camera and cutting the end of the plug of you invalidate any warrenty, why not get the jack plug extensions from Cop and the go to maplins and get the jack plg barrel and then there will be no need to make these connections and invalidate the warrenty of the camera..
