Tamper Inactive Need To Reset
cruzeur
Hello
My key pad came away from the wall and I rather innocently thought that I could undo the screw at the bottom to access the screws and reattach it. I probably don't need to tell you what happened next...... So now the panel will set the alarm but constantly says ' call installer 9651' and 'k01 tamper inactive'.
Do I need to do anything? The alarm sets and appears to function normally.
I have got from reading forums that I might be able to reset it by unplugging the battery and the removing and replacing fuse. ? In order to do this I have to remove the front of the control panel. Is that possible without upsetting the system even more?
Any suggestions will be greatly appreciated. It's a Scantronic 9651
many thanks
im guessing you got this from general electrical or diy forums, and as usual its completly wrong.
If you do this you will cause a panel tamper and depending on how your 9651 is programmed could stop it operating completly.
You could also do damage if you get something in there.
:no:
Dont matter how its progged, batt fault & lid tamp amoung others require an eng code to reset.
agreed but
makes me think its not programmed for eng reset of tampers?
