How Informative Could The Galaxy Display Be?
Terry
Hello all
We have had a new system installed - based on the Galaxy G2-20.
The system is fabulous and works a treat, it was professionally installed.
I was wondering though, if the installer could have programmed the display to be informative.
What the display shows normally is the name of the company which installed the system and their emergency phone number (which is great), but could the display not display the current status of the Alarm. For example (Fully Set; or Part Set or Night set)?
Also, can we change, add & remove the mobile numbers which receive SMS when the system is set/unset or in case of an Alarm?
Thanks for any help
System not allowed to say if set/part set etc. unless you are authorised to have that info (by putting in your code).
Would you want burglar bill to know if you forgot to set system?
Old systems used to but like you said youve had it pro fitted :)
Guest old-hand
Hello all
Thanks for any help
Not allowed to show set unset status with current regulations.
You can allocate the mobile numbers yourself and signals sent.
Menu 44 - Mobile Numbers
This option allows the SMS text messaging feature to be altered. The system can send event
messages to up to 3 mobile phones by text messaging. The type of events that are sent can be
individually selected for each of the three mobile phone numbers. In this menu option, there are
3 sub-menus, one for each of the mobile phones. On selecting a particular mobile (1 to 3) and
pressing ent, there are a further two sub-options as follows:
1 = Mobile numbers
This allows the actual mobile number to be entered. The number is entered directly by typing
the number in directly at the keypad. A number can be deleted or corrected by repeatedly
pressing the B< key. The number is saved by pressing ent.
2 = Message type
This allows the kind of events that are sent to this mobile number. There are 4 options:
1 = Alarm events
Just sends alarm activations.
2 = Alarm & set events
Sends alarms and all set & unset events.
3 = Alarm & fault
Sends all alarm events and fault conditions but not set & unset events.
4 = All events
Sends all of the above events as and when they occur.
Hope this helps
cheers
