INTEGRALSBRISTOL Posted April 2, 2009 Posted April 2, 2009 Does anybody know how similar to a compact an sms sentri panel is,Ive got to travel to look at one next week ,looking at the sms website they look the same beast ,but under the hood are they the same? protocol? codes? programming? we can do the gent range but the sms range mmmm
skippy phillips Posted April 2, 2009 Posted April 2, 2009 as fas as i'm aware they are the same, might have limited functions though
steven sneddon Posted April 2, 2009 Posted April 2, 2009 as fas as i'm aware they are the same, might have limited functions though They are exactly the same, except they can only be networked together 31 times. You can also put Gent devices on them and vice versa although you are not supposed to .
INTEGRALSBRISTOL Posted April 2, 2009 Author Posted April 2, 2009 They are exactly the same, except they can only be networked together 31 times.You can also put Gent devices on them and vice versa although you are not supposed to . ok great thanks for your help,im assuming the access codes are the same then? At least if I take a van full of gent kit with me ,I will probably have to avoid going back.By the sound sof it ,it is just a dodgey sounder anyway,showing loop open i think. thanks for your help
